I had been using VOB2MPG PRO V3.0 for weeks without any problems whatsoever, then out of the blue, now every time I get a System.FormatException when clicking the Start Extraction button.
It does it on every VOB source that I feed it. I don't think I changed anything system-wise recently to provoke this rude behavior. I tried reinstalling VOB2MPG PRO V3.0 for good measure, but I get the same error every time.
stack trace follows...
Version: VOB2MPG PRO
Build: 3.0.0700
Type: System.FormatException
Source: mscorlib
Message: Input string was not in a correct format.
InnerException:
StackTrace: at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at VOB2MPG_PRO.xfed3de3bc2a8e64d.x38aab85e6b3025d4(Ob ject xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Can you zip up the .IFO files of such a DVD and attach them here so i can investigate?
Somehow, maybe after a reboot, I was able to do some extractions for awhile, but when I came back to this particular (attached) VOB, it choked again. So I know it doesn't like this one too much.
Thanks for looking into this. -
Can you redownload from the Users Area - I have made a fix for you.
Thanks for the fix, it worked great! Quick turnaround time too!
One other anomaly I've had on occasion is the extraction will be "finished" in 2-5 seconds, but no MPG is output, and there are no other errors. In the Output Log is nothing more than the timestamp of when the extraction "finished". At first it only happened with VOBs that I authored using inexpensive software, but now I found a production DVD that duplicates the exact problem. I've attached the IFO files of the production DVD.
Thanks again!
VOB2MPG PRO can not start, please give me a refund
By xiaominghuang in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Feb 2012, 23:17 -
By xiaominghuang in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Oct 2011, 20:45 -
VOB2MPG - PRO V3: Rips Chaps 1-13 fine but not 14 - 27?
By PTR in forum SVCD2DVD & VOB2MPGReplies: 16Last Post: 22nd Oct 2010, 18:30 -
VOB2MPG PRO 3.0 Exception on start-up
By jamie4361 in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 9th Jan 2010, 02:41 -
VOB2MPG PRO 3.0.0122 No Audio and No Active Start Button
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Dec 2009, 07:50
