Hi! all. i have mkv movie files with AAC audio file. i managed to extract the audio file from the mkv using txMuxer. However, i need a converter that can convert the AAC file to AC3. any suggestions?
I would open the mkv file in Xvid4PSP, choose mkv for output, select Copy for video and set the audio to ac3. This will encode only the audio and give you an mkv with AC3 as output. It won't copy any subs, but you can use mkvextractGUI and mkvmerge to shift them across later if necessary.
Read my blog here.
Another solution is to use TFM Audio Tool. Just select the Matroska file, select AC3 as the output and designate the output file to the same location as your original Matroska file. When the conversion is completed, open the original file in Matroska Merge, deselect the AAC stream, add the AC3 stream and merge with a new file name.
Converting the audio of an .mkv from AC3 to AAC
By Anonymous4453 in forum Video ConversionReplies: 9Last Post: 13th Nov 2011, 10:39 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
My MKV file already has AAC audio so the conversion tools arent working
By animlchin in forum Video ConversionReplies: 3Last Post: 19th Dec 2009, 17:58 -
play mkv file with external ac3 audio???
By zzyzx2 in forum Software PlayingReplies: 9Last Post: 12th Apr 2009, 22:20
