Today i was recording a tv show which was a live audio concert and everything was goin on smoothly until some time later it started raining there and for some time the live telecast was stopped and the channel showed no signal...i was recording thru the software chris tv 4.99 in mpeg format...and my recording was on even when the channel showed no signal...then 2 mins later the telecast was resumed and everythin was workin well again....
now after i finished with the recordingl....i m astonished....the recorded file has audio only for the first 2 mins...and after that no audio at all.....the picture is there and perfect but no audio at all....i cannot understand why is ther no audio....
even while recordin...in d preview window there was proper audio...neat nd clear....but the recorded file has no trace of any sound after the first 2 mins ....
i cannot belive....ther was rain at that place...nd even after that the audio was clear in the preview windowl....but why then there is no audio in the recorded file...i js cant figure out !!
for details :
i use christv 4.99
the recorded file has the extension .mpg.....720 by 576...25fps....16:9 aspect ratio....
the recorded file is of 23 mins and 1.24 gb
pls help...i donno what to do now....can i repair the file with some tool or sometihin to get the audio back....??
and one more thing...the file played well in vlc media player obviously without audio...but in some other players....it played only for the first 2 mins where there was audio...and after that no audio no video...unlike in vlc where i atleast see the video...
pls help....i m in desperate need of the file with the audio....all your concern and help will be whole heartedly appreciated...thanx![]()
Make a copy of the file and then try repair it.
Use for example videoredo and use the quickstream fix and see if makes any difference.
Or demux the audio from the mpg with tsmuxer, batchdemux,, etc. Open the mpa audio in audacity and see how it looks like. -
thanx for the reply
i tried videoredo and it just makes the output file till first 2 mins which has the sound...after that it js stops and i get this as the output
Output Complete
Video resync frames removed: 25582
Video output frames: 4619
Audio output frames: 7073
Processing time (secs): 53
Processed frames/sec: 86.28
Actual Video Bitrate: 7.22 Mbps
and in tsmuxer i get this error
Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: F:\capture_19_06_09.mpg
and the tsmuxer window displays finished with error code 2
pls temme what to do now ....thanx
this is the log file of batchdemux
capture_19_6_9 is the orginal file...the ones with (2) and (3) are all created by the videoredo
BatchDemux 0.14 6/14/2005
*Please wait as the files are demultiplexed
*demultiplexing file 1
F:\capture_19_06_09 (02).mpg
Mpeg 2 Program Stream File [Video/Audio]
Muxrate : 10.08 Mbps
Estimated Duration: -1.#Js
Aspect ratio 16/9 (large TV)
Not interlaced, chroma format: 4:2:0
Video Format: PAL
Size [720 x 576] 25.00 fps 9.83 Mbps
Audio : Mpeg 1 layer 2
224 kbps 44100 Hz
Stereo, No emphasis
warning: couldn't find any valid system header. I'm continuing anyway
File F:\capture_19_06_09 (02).mpg is an MPEG-2 Program Stream
*demultiplexing file 2
F:\capture_19_06_09 (03).mpg
Video Format: PAL
224 kbps 44100 Hz
Stereo, No emphasis
File F:\capture_19_06_09 (03).mpg is an MPEG-2 Program Stream
*demultiplexing file 3
Video Format: PAL
224 kbps 44100 Hz
Stereo, No emphasis
File F:\capture_19_06_09.mpg is an MPEG-2 Program Stream
*process complete
Problem playback recorded .TS file AAC Audio
By paulc2002 in forum DVB / IPTVReplies: 2Last Post: 12th Feb 2011, 18:14 -
How do i re-encode an MPEG2 file with mp3 audio?
By snafubaby in forum EditingReplies: 2Last Post: 10th Jan 2009, 19:56 -
Recent home videos (VHS) recorded to DVD & now in Mpeg2...
By tehfreeman in forum DVD RippingReplies: 7Last Post: 19th Dec 2008, 14:12 -
Recent recorded hom evideos to DVD now in Mpeg2 format... what to do?
By tehfreeman in forum Video ConversionReplies: 2Last Post: 19th Dec 2008, 13:07 -
editing of audio file in recorded tv progr
By senilius in forum EditingReplies: 0Last Post: 27th May 2008, 11:41
