I had a commercial movie disc yesterday that refused to read, stopping at about 80% with CRC errors. I tried many times with 2 different DVD drives and different software including DVD Shrink, DVD Decrypter, and DVD Fab. DVD Decrypter reported after about 150 retries that there were 2 PGC cells that were permanently unreadable. The disc had multiple tiny scratches looking like somebody had tried to wipe it clean with an abrasive cloth, but otherwise it didn't look too bad visually. I was surprised it wouldn't read. Naturally I cleaned it several times with soap and water, then window cleaner, then rubbing alcohol. Of course I restarted my computer, and reset the DMA status of my drives. Eventually I gave up on the disc as permanently unreadable. I put it aside and worked on different discs for awhile. Then before quitting my session, I decided to retry the unreadable disc one last time. Wa la, it read OK using DVD Fab... At first it gave the usual CRC error at the 80% point, then I hit the retry button, and it read OK thereafter. I tried again with DVD Fab, DVD Shrink, and DVD Decrypter and they all read it OK. No more CRC errors. I'm really mystified. How did it convert itself from unreadable to readable? It wasn't anything I did to it, as far as I know. How could a commercially pressed DVD be so unstable?
Readability might depend on conditions of reading (like temperature), age of your drive (laser diode loses emission ability with time) etc.
Thanks for the suggestion but I don't think those factors are the cause. Both of my drives are fairly new and they read other discs just fine, rarely give CRC errors. There were no temperature extremes involved. Everything here is around 75 degrees Fahrenheit and the disc had plenty of time to equalize any small temperature differences.
"New" doesn't mean anything.
A new low-quality drive will not work as reliably as an old good-quality drive.
Temperatures are relative. Extremes not needed. Affect on humidity/moisture is plenty.
I'd have to know details on your location for analysis.
Little things like the centering of the disc on the spindle can be important, too.
The drive doesn't always load a disc the same every time.
Don't be so quick to dismiss the proven science of optical media.Want my help? Ask here! (not via PM!)
Create PS3 readable HD movies split over 2 DVD-9s?
By darrellr in forum Authoring (Blu-ray)Replies: 1Last Post: 8th Jan 2012, 10:08 -
mini DVD recorded by SONY DCR-DVD203 unreadable at DVD ROM of PC
By knightatarms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Dec 2010, 10:02 -
Saving Unreadable DVD's Part Deux
By hitechluddite in forum Authoring (DVD)Replies: 21Last Post: 14th May 2009, 09:51 -
Only First Session readable on DVD Player-- Deep Burner
By deepakOne in forum Authoring (DVD)Replies: 1Last Post: 27th Oct 2008, 02:13 -
DVD Writer recognized as Readable Only Drive!!
By lawrence_shin in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 04:15
