Hi .I was at my friends today who has a philips dvp 642/37 dvd player.He has no remote so i took mine.
I brought a few divx dvds which all worked no problem then i went into setup and there was an option for
Progressive scan. I do not remember word by word but it asked whether i would like to check if the tv has progressive scan so i pressed ok.Now the whole picture disappeared . The dvd still receives the signal ,i can tell while pressin stop/play on the remote etc it just that the tv shows no signal from the dvd whatsoever.Its an older tv i must add.
Also i tried to restart both (turned off the power) and nothing changed still tv does not show anything,just blank screen while the dvd is in play mode.
What should i do in this situation. Thx all for help.
You have to know the exact keystroke sequence to set the 642 back to interlaced. It's been posted here before.
http://www.firstglimpsemag.com/Editorial/article.asp?article=articles/2005/y0202/09y02...9y02.asp&guid=
To turn off progressive scan without menu access, just turn on the player, open the disc tray, and press 1 on the remote control.Last edited by jagabo; 3rd Jun 2010 at 20:32.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 13:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 03:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 17:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Jun 2007, 00:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 15:36
