Results 1 to 13 of 13
  1. PSCO2007
    May 2010
    Southern Ca.
    Hello all,
    I just started using Windows Movie Maker, and after I click any tools bar ( titles, etc), the bar gets stuck on my screen.
    The only way I can remove it, is to reboot.
    Any suggestions?
    Feb 2004
    Australia
    Not really the most stable of applications but try the following first.
    Click Start , click Run.
    Type the following command: %systemroot%\inf
    NOTE : There are no spaces at all in the preceding command line.
    Click OK to open the INF folder.
    Locate the file moviemk.inf , Right-click the file, and then click Install.
    Note: You will be asked to place your windows XP cd rom in the drive.
    Important: Reboot the system once completed.
    Try again and report if issue remains.
  3. PSCO2007
    May 2010
    Southern Ca.
    Don't have a cd rom.
    Anything else I can do when this occurs?
    Jul 2001
    I've only used Movie Maker a hanful of times for some small projects. The only time I've had issues is when pictures, video or audio to import were in a format (codec) that MM didn't like.
    PS: Go get a cd-rom. You can get one for $10-$15US.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
    Feb 2004
    Australia
    No cdrom ... almost unheard of these days ... not recommended method but it wont cause the system not to run as per normal.
    Follow:
    1: Download windows movie maker 2
    2: Boot into safemode and delete > program files/Movie Maker (only movie makers folder)
    3: Reboot, then install the new movie maker which you downloaded
    4: Reboot, try wmm again
    There are other files related to the performance of wmm residing in the system32 folder ... these may have been updated / tampered ... without running sfc/scannow + xp install cd you won't know if this be the problem.
    Also give malwarebytes a run on the system ... a general health checkup.
  6. PSCO2007
    May 2010
    Southern Ca.
    What I meant to say was that I had no Windows Xp cd rom.
  7. PSCO2007
    May 2010
    Southern Ca.
    Follow:
    I followed your instructions, but the download does not include Movie Maker.
Name:	WINDOWS MOVIE MAKER PIC.jpg
  8. PSCO2007
    May 2010
    Southern Ca.
    Follow:
    After spending hours getting my original movie maker back, I realized that the link you gave me was for Vista or Windows 7 - I have xp.
  9. PSCO2007
    May 2010
    Southern Ca.
    Hi Neomaine,
    Thanks for reply.
    I've got 3 dvd drives. What I don't have is an XP cd rom-which they ask you to insert.
    Bjs- who told me to download the link (and caused me numerous headaches because it is for VISTA of WINDOWS 7) caused me to lose Movie Maker and had a terrible time getting it back.
    My original problem is that when I try to insert a video into the timeline ( tried avi,divx,wma), I get an error message.
    Do you know of a codec that will make this work?
    Thanks,
    Paul
  10. Member zoobie's Avatar
    Feb 2005
    Florida
    I think it only works with DV-AVI, MPEG, and WMV filetypes...
  11. PSCO2007
    May 2010
    Southern Ca.
    Thanks for the reply,
    I tried avi and mpeg. Both gave me an error when I tried to insert it in the timeline.
    Jul 2001
    Actually, he said DV-AVI. AVI is just a container and can contain video and audio of many different types of codecs. As a catch-all, and fairly common one, you could try installing ffdshow.
    Have a good one,
    neomaine
  13. Member zoobie's Avatar
    Feb 2005
    Florida
    Corruption may also have happened - especially if the clip is from the web
    What's your source? It should be as pure as the driven snow in it's native type
