Results 1 to 17 of 17
    Jan 2006
    I'm trying to edit my fraps video, it's in 16:9. I don't know which sequence preset should I use. I tried using "HDV 1080i30 (60i)" and my video rendered with weird blackbars. Ultimately, I want to upload this video to Youtube and use 1080p. What are some settings for me to use to accomplish that without spending many hours for rendering? Thanks in advance!
  2. You would the use same specs as your footage. If you don't know what that is, use mediainfo
    Enter a custom desktop profile for the sequence settings that matches your footage. Upon export then you can scale to 1080p
    Jan 2006
    Thanks, I'm going to try that now. It's my first time doing this type of thing.
    Jan 2006
    I'm not really sure what am I doing. I rendered the video, and it had like these blackbars (top, right, bottom, left), but I don't want it to have it. I also see it in the preview, I want it to take up the whole screen.
    I think it's because of the resolution. My video resolution is 1600x900, but the sequence file created is not. I'm currently trying to find out how can I change it.
  5. I can try to walk you through it. You probably used either the wrong sequence settings, or render settings
    1st, copy & paste the mediainfo text (view=>text) and post it here
    Jan 2006
    I think I got it, I couldn't find that "Desktop" profile you were speaking of, so I was using some random one.
    Jan 2006
    Actually, I would like that walk through please
    General
    Format                           : AVI
    Format/Info                      : Audio Video Interleave
    File size                        : 3.91 GiB
    Duration                         : 3mn 3s
    Overall bit rate                 : 183 Mbps
    Video
    Format                           : FRAPS
    Codec ID                         : FPS1
    Duration                         : 3mn 3s
    Bit rate                         : 181 Mbps
    Width                            : 1 600 pixels
    Height                           : 900 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 30.000 fps
    Bits/(Pixel*Frame)               : 4.192
    Stream size                      : 3.87 GiB (99%)
    Audio
    Format                           : PCM
    Format settings, Endianness      : Little
    Format settings, Sign            : Unsigned
    Codec ID                         : 1
    Codec ID/Hint                    : Microsoft
    Duration                         : 3mn 3s
    Bit rate mode                    : Constant
    Bit rate                         : 1 536 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 48.0 KHz
    Bit depth                        : 16 bits
    Stream size                      : 33.6 MiB (1%)
    Interleave, duration             : 998 ms (29.93 video frames)
  8. what version of premiere ?
    Jan 2006
    CS4, also, could you show me how to lower the volume for a certain part of the video?
  10. the sequence settings should match you input footage
    for audio, the easiest way would be to use keyframes. You move your CTI (current time indicator, or playhead) to a section and push the keyframe button. Move it farther on and push it again. You can move the section between the keyframes up/down to alter the volume. You'll figure it out when you fiddle with it
    For export settings, 1920x1080, square pixel, 30.0FPS
    Jan 2006
    Thanks for the help, it worked great! How can I make the audio track vertically bigger? I know in Sony Vegas, you can make it wider and vertically bigger, but I can't seem to find it in Premiere.
  12. Just click and drag it to make it vertically larger (drag near the lower end, underneath the keyfram button, where the "1" is in the screenshot above)
    Jan 2006
    Thanks for the help! I really appreciate it
    Jan 2006
    I just uploaded my video and it only went up to 720p on youtube, but I wanted 1080p. Is it because my resolution is to small?
  15. It sometimes takes a few hours for the 1080p version to show up on YT, there is usually a delay
    But to double check, are you sure your export settings were correct? What does mediainfo say about the exported file?
    Jan 2006
    It seems I didn't change the resolution upon export.
    Format                           : MPEG-4
    Format profile                   : Base Media / Version 2
    Codec ID                         : mp42
    File size                        : 204 MiB
    Duration                         : 5mn 35s
    Overall bit rate                 : 5 107 Kbps
    Encoded date                     : UTC 2010-06-03 23:16:00
    Tagged date                      : UTC 2010-06-03 23:16:00
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : Main@L3.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 4 frames
    Codec ID                         : avc1
    Codec ID/Info                    : Advanced Video Coding
    Duration                         : 5mn 35s
    Bit rate mode                    : Variable
    Bit rate                         : 4 978 Kbps
    Width                            : 1 280 pixels
    Height                           : 720 pixels
    Frame rate mode                  : Constant
    Frame rate                       : 29.970 fps
    Standard                         : NTSC
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.180
    Stream size                      : 199 MiB (97%)
    Language                         : English
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format version                   : Version 4
    Format profile                   : LC
    Format settings, SBR             : Yes
    Format settings, PS              : No
    Codec ID                         : 40
    Duration                         : 5mn 35s
    Bit rate                         : 127 Kbps
    Maximum bit rate                 : 180 Kbps
    Channel positions                : Front: L R
    Stream size                      : 5.07 MiB (2%)
    Language                         : English
  17. You must have used the wrong export settings in AME. Review your settings
