Hi, I have an old Samsung camcorder, which uses tape, and I would like to get the video off one of the tapes onto my PC. Could somebody please tell me how to do this? I am a complete beginner and have no idea at all what equipment or software I need for this. Any advice would be appreciated. Thanks in advance.
A DV-Camera? Use the firewire connection.
If you want more details then give us more details about the camera.... -
Hi Baldrick, thanks for getting back to me. The camcorder is Samsung model VP-J52. What is a firewire and how does this connect to my PC? And once connected, how do I then transfer stuff through it to my PC? Please excuse my complete lack of knowledge on this!
A Samsung VP-J52 is an 8mm analog format camcorder. You would need an analog capture device. You don't list any computer specs.
Some examples.
USB2
http://www.newegg.com/Product/Product.aspx?Item=N82E16815306013
http://www.newegg.com/Product/Product.aspx?Item=N82E16815100033
PCI
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=15-116-020-S02&SCList=15-116-...CI%20Interface
PCIe
http://www.newegg.com/Product/Product.aspx?Item=N82E16815306023Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I used to play an anologue camcorder into a domestic HDD/DVD Video recorder and then copy the files from the DVD recording into the computer. Then use converter software to make a file suitable for the editor. Tiresome but effective. (my reply to an earlier thread. you don't give your location. if you are in usa such recorders may not be common).
... cheers Mike
Best HD camcorder that can record onto tape?
By alexh110 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 10th Oct 2011, 10:20 -
Convert analogue camcorder tape to pc
By ManUtdFans in forum Capturing and VCRReplies: 9Last Post: 29th May 2011, 22:59 -
Will a Digital 8 camcorder read 8mm tape?
By Tenacguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jun 2009, 14:24 -
Get tape out of dead camcorder
By mickseven in forum Newbie / General discussionsReplies: 3Last Post: 24th Jan 2009, 15:21 -
Broken camcorder or damaged tape?
By eliw777 in forum Capturing and VCRReplies: 11Last Post: 29th Dec 2008, 00:09
