Is it possible?
I have found a similar thread that got no reply: https://www.videohelp.com/forum/archive/how-to-record-mms-vod-movies-with-offset-t353868.html
Have you tried with latest VLC? Or do you get same error as in that other post?
The only method I know that would work is to use a screen capture tool. Maybe WM Capture or Replay Video Capture. -
It does not give an error but simply stops the video if I try to navigate. I am aware of screen capturing software, but for me there is no point of recording if the original quality is unkept.
I also tried changing Start Time in VLC, but then the stream does not load.Last edited by Kanadon; 3rd Jun 2010 at 13:05.
I've been able to do that with WebVideoCap by creating a .asx playlist with a starttime value. Example:
<asx version = "3.0">
<entry>
<starttime value = "0:30.0"/>
<ref href = "mms://us.msmobvid.wm.msn.com/a1602/d2/PROD/MSNvideo:The%20Surf%20Report/10150/4b5742a2-0126-499b-bbc5-58e5a9f04713.wmv"/>
</entry>
</asx>
Need help downloading an MMS stream, details and code inside...payment
By robbo64 in forum Video Streaming DownloadingReplies: 3Last Post: 10th Apr 2011, 19:11 -
Help with seting up stream for mms
By ggnetworks in forum Capturing and VCRReplies: 1Last Post: 24th Sep 2010, 01:11 -
Playing only sound from MMS stream
By igorek in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2008, 16:38 -
how to embed wmp in a webpage for a live stream mms://
By mladost13 in forum ProgrammingReplies: 4Last Post: 11th Jan 2008, 13:56 -
Capturing Live MMS Stream
By interfacemirror in forum Capturing and VCRReplies: 0Last Post: 30th Jun 2007, 13:37
