Hi friends,
I am going to buy a WD player for work (for home I have a NMT C-200)
The remote looks pretty simplistic, and the "Rev" button cannot mean anything else than a "play backwards" but still I would like to hear a confirmation from someone who has it:
1. Does WD payers play backwards. For our purposes (show educational videos to students) it is very convenient to be able to go back a few seconds then play again normally.
Same (or even) better effect would be achieved if they had a "A-B" button, but they don't.
2. Is it a risk to buy a "recertified" one:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136452&cm_re=wd_media_player_h...-452-_-Product
Thanks !
Best wishes,
UP -
I don't feel comfortable with that word "play" as that implies something to me that you may not mean, but yes, the WD players can go backwards in video by pressing the Rev button. The video skips backwards so it's not really like playing backwards, at least not to me. It's not particularly precise, but basically you can do what you want to do, yes. Just note that you may have to go back, say, 15-20 seconds instead of just a few seconds depending on your video type.
I would not think it's a risk to buy a recertified player. I bought a recertified Norelco electric razor over 8 years ago and it still works. But of course I cannot give you a personal 100% guarantee that you will not have any issues, but in general I think it should be OK.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
video player that can step forward/backwards and change play speed
By wildflow in forum Software PlayingReplies: 5Last Post: 5th Jul 2012, 19:16 -
Backwards running
By Zenner in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:41 -
Magnavox Blu-ray player US$80 (recertified)
By jagabo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Nov 2009, 21:14 -
USB 2.0 hubs (backwards compatable)
By guitardan in forum ComputerReplies: 4Last Post: 25th May 2008, 11:01
