Results 1 to 9 of 9
  1. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I would like to down convert an existing MKV file that is 1080p to 1080i or 720p using Handbrake. What would be the appropriate settings ?
    General
    Complete name : K:\MKV_1080p\Wedding reception
    Format : Matroska
    File size : 7.90 GiB
    Duration : 2h 00mn
    Overall bit rate : 8 472 Kbps
    Encoded date : UTC 2007-09-04 19:11:39
    Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Muxing mode : Container profile=Unknown@5.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 00mn
    Bit rate : 7 920 Kbps
    Nominal bit rate : 8 338 Kbps
    Width : 1 920 pixels
    Height : 816 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.202
    Stream size : 7.43 GiB (93%)
    Writing library : x264 core 56 svn-667C
    Encoding settings : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=8338 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=186543,195312,b=0.18 / aq=1:0.3:15.0
    Language : English
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 2h 00mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 369 MiB (5%)
    Language : English
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Language : English
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Convert to what?
    And why? It is already over compressed.
    http://www.kiva.org/about
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Their (my friends) media player will not play mkv files that have been encoded to 1080p but will handle 1080i or 720p ok - so as I said in my post I wish to use Handbrake to downscale this file to 720p or 1080i - same encoder etc. In other words if they had been given a 720p version to start with there wouldn't be a problem. The original no longer exists (freelance cameraman) so this is what I have to work with. Above all content is more important than whether the file is "over compressed" or not - actually it looks very good with professional lighting and exposure and when played on studio quality gear no obvious artifacts etc.. If you haven't actually got some positive suggestions don't bother replying.
  4. Member edDV's Avatar
    Mar 2004
    Do you know what camera the (freelance cameraman) was using? 1080p/25 is not common unless transferred from film.
    And no professional would offer a delivered product in an mkv wrapper. That is unless he/she was trying to prevent copies. Didn't you get a Blu-Ray? There must be a camera original somewhere. Maybe a lawyer would be more effective.
  5. 2:35:1 AR and 1920x816 wouldn't be very common shooting formats either...
    But anyways, what media player ? Some have specific restrictions, and you may have to some extra stuff
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I'm not in the USA where suing is common and besides he was a friend of the people (works in the industry) and not sure what camera maybe a RED? but I think it was a special arrangement. Anyhow I don't care about a deep analysis of the origins just interested in a solution. So if anyone knows the appropriate settings in Handbrake to downscale it that's what I'm interested in finding out. I'm a task driven person so if someone asks me how to do something I simply answer with the facts if I know them, I don't try to conduct 20 questions that's not the purpose of a video forum. If you don't know then consider the discussion closed.
  7. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Just found out the camera was a RED http://www.red.com/cameras/
  8. Member edDV's Avatar
    Mar 2004
    Since the file is titled "Wedding Reception" I thought you were being gamed by a wedding videographer.
    A Red can shoot 2.35 aspect 1920x816p at 25 fps. Few other cameras can.
    For 1080i, you want to letterbox out to 1920x1080 (add 132 lines top and bottom), then recode 1080i/25 interlace, or for 720p, resize 1920x1080p to 1280x720p, then encode.
    Handbreak is normally used to crop out letterbox rather than add it. I'll have to look closer at the settings to see if this is possible.
    Maybe if you simply recode the 1920x816p to MPeg2 or xvid, the player might add the letterbox.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    afaik handbrake will only make progressive mp4 or mkv. also it doesn't have an add borders feature only cropping. vegas, pp, an avisynth script, or maybe virtualdub might be able to do it.
    can you cut and post a sample for people to test?
