Dishnetwork offers a DVR service for it's 211 HD receivers with an external Hard Drive. Dose this mean that USB jacks can be used to capture satelite broadcast?
Results 1 to 13 of 13
Not necessarily. Ask Dish network if they support external drives. If they do the files on the drive would be encrypted and linked to your account. You could only use that drive on that specific box with an active account.
http://www.kiva.org/about -
Does that mean that programs recorded on the external HD could not be transferred to a computer?
If they even support external drives, yes.
Several cable DVR boxes have this feature to allow expansion of recording time. The drives are formatted with a proprietary OS and all files are encrypted. They are tied to a specific box and an active account. If you cancel the account the files can't be recovered.Recommends: Kiva.org - Loans that change lives.
I setup an external HD. I first hooked it up to my computer to confirm it worked and could read the files on it,which it did. Then I activated the DishNetwork DVR service on my 211 receiver and recorded a movie. It worked fine on my Dishnetwork receiver. Then I hooked the external drive back on my computer and the computer didn't even recognize the external HD. Now I wonder if the HD in the external USB case can be reformatted back to windows?
As far as I know, you can't transfer files from Dish DVR HDDs to a computer, except for a few older models supported by PVRExplorer (available from SourceForge http://sourceforge.net/projects/pvrexplorer-pro/).
deleted because I need glasses.. sorry about that, wulf109.
-vhelp 5389Last edited by vhelp; 6th Jun 2010 at 17:57.
Do the HD's in DVR's spin down while the unit is on and being used only as a receiver? Does the external HD attached to the 211 receiver spin down while the receiver is used only as a receiver?
No, the disks spin whenever the unit is on. There's a rewind/pause buffer for live TV.
You are correct, I am blind.. posted blog deleted.Dishnetwork offers a DVR service for it's 211 HD receivers with an external Hard Drive.
-vhelp 5391
Recording satelite TV with Panasonic DMR EH59
By bjuice in forum DVD & Blu-ray RecordersReplies: 20Last Post: 3rd Sep 2012, 18:22 -
USB 500 capture
By kortmann in forum Capturing and VCRReplies: 2Last Post: 18th Sep 2010, 18:44 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 15:04 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05
