I have a transport stream from my DVR. I would like to split the video to remove advertisements from the beginning, and the advertisement from the commercial break in the middle, then convert the ts to a more manageable mkv.. Is there a program(s) that can do this? I currently use both MeGUI and MediaCoder to get my video conversion done, but I can't find a way to either split the video into two separate files and remove the advertisements, or split the video during the conversion for a correct output. Is there a way to do this? MediaCoder only allows cutting from one specific spot to another, but I need to do it with a small break in between.
Thanks..
Transport stream with h264 or mpeg2 video? Identify with mediainfo.
avidemux might work for some ts streams, t can edit and save as a mkv. Or else try edit with the free tssniper or videoredo preview. Convert with megui, mediacoder as usual. Maybe you could also make a custom avisynth script for megui to cut the advertisement.
How can I ACCURATELY split/cut a video file?
By KushSmoka420 in forum EditingReplies: 5Last Post: 2nd Mar 2012, 14:16 -
No video in virtualdub after cut and split avi
By cooljoe666 in forum Video ConversionReplies: 10Last Post: 10th Jan 2011, 15:19 -
automate video screenshots at intervals
By scarecroe in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2009, 15:43 -
How do I split a video into multiple files?
By chipped in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2008, 05:33 -
FFMPEG: Extracting multiple frames at different intervals
By roden in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2007, 11:35
