Yep... me again,
In other threads I mentioned how my 5.1 setup was only playing in Stereo. However, a couple days ago I fixed it... all 6 channels playing exactly as they should. Unfortunately, I was experimenting with so many things in so many ways that I can't pinpoint what it is that fixed it. Yesterday, it reverted againNow, it's back to nothing but Stereo and I have no clue what I did to make it that way
If it helps you to help me, I should mention that I'm running Windows 7. I have AC3Filter installed and properly configured. I uninstalled and reinstalled my sound card... didn't help. I uninstalled and reinstalled Soft Encode... didn't help.
When I do fix this again, I'll be sure to backup my registry!
I was in the middle of a project, which was working fine. Then, for some unknown reason, it got screwed up again. I'm eager to resume my work, but, of course, I can't.
Please help
Thanks (again) in advance,
Justin
EDIT - What does work is to use Audition's Surround encoder and export a single 6-channel interleaved Wave. If I then use VirtualDubMod and use that Wave, it'll play back just fine... in VirtualDub. I haven't checked how it plays back in anything else. I tried using eac3to to convert the Wave to AC-3, but the AC-3 ends up playing back incorrectly as well.
Results 1 to 1 of 1
Last edited by takearushfan; 2nd Jun 2010 at 16:16. Reason: Adding additional info, that might help.
CSS : Confusing as ever...help??
By beavereater in forum ComputerReplies: 2Last Post: 8th Jun 2011, 02:25 -
XP Installations. Big problems.
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 9th Mar 2010, 10:43 -
Windv confusing troubles.
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 11th Dec 2009, 16:36 -
Confusing Right with Left...
By Thortok2000 in forum Newbie / General discussionsReplies: 17Last Post: 29th May 2007, 17:30 -
By Thortok2000 in forum Capturing and VCRReplies: 1Last Post: 29th May 2007, 10:50
