i got this error in the logs when trying to encode a mov file (h264 video, aac audio) to flv (ffmpeg flash video, mp3 audio).
i also tried converting using quicktime (see options in the Options tab), with no success.
it happens with some files only of the batch i'm encoding.
thank you
here's the complete log file:
<pre>
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/path-to-file/filename.mov':
Duration: 00:07:36.6, start: 0.000000, bitrate: 883 kb/s
Stream #0.0(eng), 30.00 fps(r): Video: h264, yuv420p, 512x288
Stream #0.1(eng): Audio: aac, 44100 Hz, stereo
Output #0, flv, to '/path-to-file/filename.mov.ff.flv':
Stream #0.0, 25.00 fps(c): Video: flv, yuv420p, 512x288, q=2-15, pass 1, 200 kb/s
Stream #0.1: Audio: mp3, 44100 Hz, stereo, 160 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Wed Jun 2 14:50:03 CEST 2010
[aac @ 0x54340c]faac: frame decoding failed: Gain control not yet implemented
Error while decoding stream #0.1
[aac @ 0x54340c]faac: frame decoding failed: Maximum number of scalefactor bands exceeded
[aac @ 0x54340c]faac: frame decoding failed: Scalefactor out of range
[aac @ 0x54340c]faac: frame decoding failed: Channel coupling not yet implemented
[aac @ 0x54340c]faac: frame decoding failed: Pulse coding not allowed in short blocks
/bin/sh: line 1: 1028 Bus error /Applications/ffmpegX.app//Contents/Resources/ffmpeg -i /path-to-file/filename.mov -y -map 0.0:0.0 -f flv -vcodec flv -b 200 -aspect 16:9 -s 512x288 -r pal -g 240 -me epzs -qmin 2 -qmax 15 -acodec mp3 -ab 160 -ar 44100 -ac 2 -map 0.1:0.1 -benchmark -pass 1 -passlogfile /path-to-file/filename.mov.ff.flv /path-to-file/filename.mov.ff.flv
</pre>
Apparently your MOV file uses some special features in the AAC audio that the ffmpeg version in ffmpegX does not understand (yet) or finds 'illegal'. No setting in ffmpegX can change that.
You may have to prep your file by converting (with a different tool) first to a file with simpler/more compatible audio. The trick is to find such a converter tool that can handle this specific audio. Perhaps QuickTime Pro can?
The 'Decode with QuickTime' option is only for the video. ffmpeg is still used for audio decoding. The 'Decode with QuickTime' option won't make a difference if the encoder fails because of an audio decoding error.Originally Posted by vthirteen
Update on ATI TV Wonder 650 USB Auto Gain Control (AGC) Issue
By Mini-Me in forum Capturing and VCRReplies: 7Last Post: 22nd Aug 2013, 09:39 -
ffmpeg faac frame decode failed
By fobster in forum Video ConversionReplies: 2Last Post: 28th Mar 2008, 07:10 -
Vista - Control panel failed to open with Realtek ac97 unistalled?
By amdk62 in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 14:15 -
Automatic Gain Control in dvd-player?
By dynamique in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th Sep 2007, 10:34 -
mkv: error decoding the frame
By andyx181x in forum ffmpegX general discussionReplies: 4Last Post: 28th Sep 2007, 02:30
