What would be the best quality app to convert this AMAZING (and I mean AMAZING looking mp4 file) to DVD without much (if any possible) loss in quality? I usually use ConvertX for the speed.. but is there something that would give me even better results quality wise, dont care about speed as I have a Quad Core, 4GB RAM system running Vista 64bit.
here is the mediainfo from the file :
General
Complete name : C:\Users\****\Downloads\NHL 4-20-10 WCQF Game 4 Phoenix vs Detroit 720p ENG H264.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 3.07 GiB
Duration : 1h 50mn
Overall bit rate : 3 964 Kbps
Movie name : NHL 4-20-10 WCQF Game 4 Phoenix vs Detroit 720p ENG H264.mp4
Performer : Avidemux
Writing application : Lavf52.39.2
Video
Format : AVC
Format profile : High@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 1h 50mn
Bit rate mode : Variable
Bit rate : 3 826 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.069
Stream size : 2.96 GiB (97%)
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 50mn
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 101 MiB (3%)
You will lose quality. 1280x720 pixels to 720x480pixels....
But I would use avstodvd instead of convertxtodvd. -
i have tried avstodvd but couldnt get the thing to work for some reason.. do you have to install any seperate encoders with that? I would start the convert process and it would just hang (not responding) on the encoder window no matter which of the 3 I choose from the preferences window. Are there settings I should change or set in that program? What would give me the best quality in that program?
Advice for DV Tape 4:3 to 16:9 cropping and converting for Virtualdub
By frmys in forum Video ConversionReplies: 2Last Post: 6th Dec 2011, 14:32 -
Advice on converting and improving SD video to HD
By wyclef in forum Newbie / General discussionsReplies: 18Last Post: 17th Jan 2011, 20:22 -
New Sanyo CA-100, need converting advice
By Blue407 in forum Video ConversionReplies: 1Last Post: 2nd Dec 2010, 02:30 -
Need some advice on converting software
By fender4645 in forum Video ConversionReplies: 0Last Post: 9th Apr 2010, 17:03 -
Advice on converting TV recorded .TS to AVI or H.264
By doveman in forum Video ConversionReplies: 8Last Post: 22nd Apr 2009, 09:06
