I was not satisfied with analog capture from my analog Camcorder.
So I bought a digital viewcam and a firewire card.
The ULEAD software download the AVI file okay, the avi look good.
I convert it to NTSC SVCD with TMPGenc 12a.
THE RESULT IS PRETTY BLOCK and COLOR IS DULL.
IT IS WORST than ANALOG CAPTURE!
Maybe I did not optimised it enough, please tell me
is it me, or it is the DVCAM digitized AVI problem ?
What is the resolution of the downloaded AVI ? Is it interlaced ?
What is the different detween TI 1394 and MS 1394 option ?
Is this just the 1394 command and have nothing to do with video quality ?
Do the mpeg2 quality better if the Digital Image stablizing is off ?
DVCAM suppose to be as good as DVD, but AVI files are hue.
WHAT DO I have to do to get GOOD Video quality SVCD ?
Er, I assume I am not the only one bought Digital Camcorder to make Home Video SVCD ?
It will be great if the guru can shared some tips.
Thank you.
Sony DVCAM
By gash69 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2011, 10:36 -
DVCam or DVCpro?!
By B-Twien Bytes in forum MediaReplies: 0Last Post: 18th Oct 2009, 08:32 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 22:46 -
The baby thread (aka Will Hay question)
By stiltman in forum Off topicReplies: 1Last Post: 22nd Aug 2007, 23:23 -
New ActiveX (aka viruses and trojans)
By stiltman in forum Off topicReplies: 0Last Post: 16th Aug 2007, 11:26
