Ripped in vob, and mkv. Both look grainy. Usuing wd live media player. Shouldn't picture look crisp? Thank you, marccc
If it's an SD source (VOB from DVD) , it will never look crisp on an HDTV
720x480 vs. 1920x1080 -
If it's a retail DVD (i.e. VOB), that's standard definition
You might be able to reduce the "graininess" a bit by using a higher bitrate, or even playing back the original (without compressing it farther) but it will never look crisp on a HDTV. You need an HD source. -
Your "rips" played with the WDTV Live should look about the same as playing the original DVD on a DVD player. Unless you recompressed with too low a bitrate and/or a smaller frame size.
How do I ajust the sharp/softness on my Panasonic VCR? Picture seems grainy
By daysaf00 in forum Capturing and VCRReplies: 76Last Post: 30th Jan 2014, 16:21 -
New to Plasma/LCD/LED. Should I buy this plasma screen if I'm a gamer?
By Hank Kinsley in forum DVB / IPTVReplies: 4Last Post: 1st Nov 2010, 16:33 -
The picture on Plasma keeps going out then comes back on!!
By marionr26 in forum DVB / IPTVReplies: 4Last Post: 7th Oct 2009, 23:56 -
Picture is grainy
By tn2006 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 4th Feb 2008, 12:34 -
Help With Grainy Looking Video
By MAXIMUS01CAN in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 30th Jan 2008, 17:00
