Results 1 to 10 of 10
  1. can anyone let us know what's "EPS" files or how to play "eps" extension files ??
    Actually, I got it from my friend but unable to play it..
    Encapsulated PostScript...
    Have you disabled hide extension in windows? So you see the real extension? Or open the file in mediainfo to check.
  3. hmm..
    How to disable hide extension in windows ??
    I am also attaching mediainfo screenshot for your reference..please check and revert back
    form
    vikas
    Maybe it is an Encapsulated PostScrip? http://en.wikipedia.org/wiki/Encapsulated_PostScript
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    48 MB would be very big for an EPS graphic. Possible if it contans a high definition bitmap.
    If you have Adobe Acrobat (the full version, not just the viewer) you can use it convert EPS to PDF.
    If it is Encapsulated PostScript, you can see the header of the file some ASCII like
    Use a text editor, eg Notepad.
    %!PS-Adobe-3.0 EPSF-3.0
    %%Title: (Map.pdf)
    Drawing graphics programs like Adobe Illustrator, Corel Draw, can also read and show these.
  6. Mod Neophyte redwudz's Avatar
    USA
    Originally Posted by vikas.babu View Post
    hmm..
    If you're asking, go to 'Control Panel>Folder Options>View' and scroll down the list. Uncheck 'Hide extensions for known filetypes'.
    Then you should be able to see and change an extension. MS has the 'feature' turned on by default.
  7. IF it is truly an encapsulated postscript file that DOES end in .eps, you can convert it to a PDF with the free PDFill software:
    www.pdfill.com
    The program will install the free PDFill Tools (which has all sorts of PDF/EPS utilities), the free PDF Writer, and the Trialware/Payware PDFill Editor.
    It will then offer to automatically download and install GhostScript, which is needed for PDFill.
    Feb 2004
    Pleasant Hill, CA
    Irfanview can view EPS files as well, with a plugin (and Ghostscript as well). I've used it a couple of times for this (it's my image viewer of choice).
    http://www.irfanview.com/
    Just another option....
  9. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Does Irfanview really view the EPS graphic, or just the preview; as not all EPS files have a preview.
    Ghostscript (and a GUI, GSview), certainly can.
    Anyway, as I said above, look in the header to see if it actually is EPS first.
    Feb 2004
    Pleasant Hill, CA
    I don't know enough to be able to answer that. I just know that the couple of EPS files I have, I can view them in Irfanview.
    I guess YMMV.....
