Hi there,
is there anyway to uncompress demuxed VC-1 streams from Blu-ray to a MOV file?
Best regards.
Results 1 to 10 of 10
Moving you to our conversion section.
Nope, I don't know any easy method to convert to uncompressed mov. -
What do you mean by uncompressed? Do you mean without any additional compression or recompression? (VC-1 is already highly compressed.) Or do you literally mean as uncompressed RGB or YUV video? Uncompressed will give you very large files -- about 540 GB/hr for 1920x1080, 24 fps, uncompressed RGB.
I have meant uncompressed YUV, I am aware of size it will became
Just looking for a way to do this, it's for editing purposes
Convert Webcam Video for TV - uncompressed avi > asf > mov - best solution?
By nakedgun in forum Video ConversionReplies: 0Last Post: 17th Nov 2011, 06:41 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
Uncompressed mov / Blu Ray authoring
By brettwtfi in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Mar 2010, 14:25 -
MOV to Uncompressed AVI
By sdiddy in forum MacReplies: 11Last Post: 8th Mar 2008, 10:10 -
Need to export from Avid Meridien Uncompressed Mov to something else Uncomp
By rgabel in forum MacReplies: 1Last Post: 2nd Oct 2007, 12:54
