a friend of mine has TIVO
I up course have Over the Air Digital with an ElGato set up
to him!
but he wants to move some shows over to his HD
Im guessing that would be difficult as TIVO has some sort of ...whatever... to prevent this
what the groups view?
if you can get over the air HD do it. of course there is no cable over the air as far as I can Sniff!
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
If your friend will be satisfied with an SD copy, and the recordings he wants to save are not copy protected you can possibly capture (re-record) the output of his TiVo to his Mac's HDD using the Elgato EyeTv.
If his TiVo supports the feature, and the programs he wants to keep are not copy protected, there is also TiVoToGo for Apple Macintosh computers. He will need Roxio Toast Titanium 8 or higher.
Tivo to Mac
By tvmonkey in forum MacReplies: 6Last Post: 24th Oct 2010, 17:47 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 06:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
Tivo files to other formats on a Mac
By whoisquilty in forum MacReplies: 3Last Post: 9th Mar 2010, 18:35 -
Transfer files from Mac to Tivo
By whoisquilty in forum MacReplies: 3Last Post: 8th Jan 2009, 14:56
to him!
