Hello all
I followed the, DivX to VCD All-in-one Guide
and ended up with a great looking movie with
audio that's perfectly synced. The only problem
is its over 1GB in size.
The AVI file started out as a 717MB file that fit
onto a single CD. So, I wasn't aware it was going
to grow to this size.
So now, what do I do?....
TIA
Why doesn't this work?
Check out the EDIT section under the HOW TO menu on the left to learn how to cut the mpeg movie into two files that'll each fit on one cd.
Thanks Kmiura182 for the reply. That's what I thought,
but the tutorial mentioned this step prior to hitting the
Start button. So I wasn't prepared when I ended up with
something so large, when I actually started out with a
movie that fit on one CD.
Thanks again, I'll give it a try.Why doesn't this work?
