OK. I opened TsMuxerGUI and demuxed a ts file I have.
Then I opened MKVMergeGUI and loaded the H264 and AC3 files on it.
Problem is it asks for the fps spec, and the file's is 50fps. No such option, only 25, 24 and 30.
How can I solve that?
I did try changing fps in TSMuxer, but it gave me an error. Any other way to convert that file?
You should be able to set it manually to 50fps in mkvmergegui / mkvtoolnix, see https://forum.videohelp.com/threads/320999-AVC-in-mkv-plays-with-half-the-frame-rate?p=...=1#post1987650
Thank you. It did work writing the value manually.
Things play nice and in sync.
Converting MKV to DVD compliant file
By carlmart in forum Video ConversionReplies: 18Last Post: 15th Apr 2011, 11:51 -
Converting DVD to MKV file
By thearm in forum DVD RippingReplies: 5Last Post: 11th Nov 2009, 07:34 -
Problem Converting MKV file with MKVtoVOB
By AllenM in forum Video ConversionReplies: 5Last Post: 2nd Mar 2008, 12:59 -
Converting MKV to a smaller MKV file
By Boriskali in forum Video ConversionReplies: 3Last Post: 1st Dec 2007, 06:07 -
Problem converting .MKV file
By craig3975 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Sep 2007, 12:19
