    May 2010
    santa monica, CA
    Does anyone know if DVD Studio Pro can properly display vector graphics? I'm having trouble bringing in a graphic originally done in Illustrator, flattened into Photoshop as the background and brought into DVD Studio Pro. It doesn't look good, appears pixelated in DVD Studio Pro. I tried placing the image as a smart object in Photoshop and even rasterizing that layer in another try but both had the same results a low res looking image of poor quality. Thanks. Nancy
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Did you follow the steps for importing graphics in the DVDSP manual, pp 97-101 ?
    specifically taking note of the section marked "Understanding differences in Pixel Graphics and Video"?
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Jun 2010
    Polska
    Importing graphics into DVDSP, you must be sure it has proper resolution and proper pixel aspect ratio.
    Don't know if you are editing in PAL or NTSC. There few differences between those broadcasting formats.
