...Dialogue normalization, Bit stream information, Audio production information, Preprocessing settings (such as what Compression characteristic was used, if any), etc.?
Things like the audio bit rate and channel count are trivial to determine, but is it possible to find out the more advanced settings that were used when encoding, such as outlined above?
Thanks,
Justin
I think only the companies that produce the dvds have that information. There may be generic "if this then they used this" kind of approaches. I don't think there is any meta data that can be extracted from commercially produced dvds to find that information out.
There may be general information available on wiki or imdb for movie specific creation paramaters. Though you may not get as specific information as you may want.
Though I could be wrong but I doubt that is available for any given dvd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks for the reply. Yeah, I had a feeling there's really no way to find out. It'd be interesting if someone could write an app to figure it out though. However, that'd probably require an enormous amount of various math skills and intense and complex coding skills.
megui 64 bit mode avs4x264mod.exe
By killerteengohan in forum EditingReplies: 0Last Post: 10th Mar 2012, 23:10 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
What is the name of this video/audio info tool?
By ZoNi011 in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2010, 04:53 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Tool for DVD-RAM version/revision info
By VirtualDoobMon in forum ComputerReplies: 2Last Post: 8th Aug 2008, 23:25
