I'm trying to convert a DVD that was made with PAL to NTSC and I've been following the guide on the digitalFAQ website: http://www.digitalfaq.com/guides/video/convert-pal-ntsc.htm
Everything has gone fine up until the point where I am using Goldwave to convert the AC3 audio to WAV format so I can continue on with the process.
I have a tried several times but the resulting WAV file has no sound (even though the size of the WAV file shows that it has information and is relatively large in Bytes/size).
It seems like there is a codec missing or something but I don't know what's wrong. I can play the AC3 files with VLC media player so I know those files are good. But even if I play the WAV file with VLC it has no sound.
What am I doing wrong??
Wow! I don't know what that did but it fixed it...lol
Thanks a lot Baldrick!
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35
