Since I bought this non-consumer mess Dec 2009, I have not been able to get many files onto the computer. And then, what file do you use to even view your videos?
What I have been able to download to the computer I can't open/view, let alone burn DVD. I need a low cost S/W that can convert .mts files into something burnable/viewable.
I know this is my lack of knowledge and I am way over my head with this camcorder. Any help would be appreciated.
Results 1 to 10 of 10
Try avidemux. If you want fancier editing, try Adobe Premiere Elements. You can check out the trial version to see if it suits you.
Also, it's pretty stupid to choose your username based on your problem. It shows that you probably won't contribute here beyond (possibly) getting an answer to your question.
I know people that have that camera, and they've made some great videos. It sounds like user error at this point that can only be fixed by research and practice.. -
You can use splash or MPCHC to view the clips
If you are burning a standard DVD (playable in a regular DVD player) , it will be SD, you will lose HD. You could use avstodvd , or dvd flick , for example
If you have a blu-ray player, or PS3, you can use HD content on DVD media. You could use multiavchd for this -
it's very nice cam(from reviews) just fallow the advice by both Supreme2k, and poisondeathray
I was thinking about picking a refurb one for $399
http://www.techbargains.com/news_displayItem.cfm/210125 -
Tigerdirect has refurbs also I just noticed
http://cameras.pricegrabber.com/camcorders/canon+hf200/p/47/form_keyword=canon%20hf200...oo_us_adv/rd=1 -
Exactly what kind of PC are you using? AVCHD is very processor intensive and will need all h/w muscle it can get just to play smoothly, let alone edit. A core2duo is a basic start for a processor, all the way to i7. You need at the very least dedicated graphics, not the so-called on-board. And the PC you intend to do any AVCHD-related activity in should be lean (as in bloat-ware free, no fezbuk blah-blah), with separate system and capture drives which should ALWAYS be defragged. Canon and their ilk like to make an unsuspecting public think that AVCHD is a walk in the park, so you go and buy things HD this and HD that and now you find it's hardly like what they said. Tough. Peruse this forum.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
Go to the store and get a newer computer to go along with your new camera.
Windows 7 with the latest Windows Media player handles .MTS just fine.
Hell, my Old I-3 laptop will even play 24mbps .mts files..
Canon HF200 help
By descotes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Oct 2010, 15:28 -
Canon HF200 and Premiere CS4
By tapaza in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 22nd Feb 2010, 08:49 -
2 Mics for the Canon HF200... How?
By juststarted in forum AudioReplies: 3Last Post: 25th Nov 2009, 16:23 -
Buyer's Remorse on a Canon HF200
By Genison in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 28th Aug 2009, 23:53 -
Canon HF11 or HF200?
By David97 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2009, 11:09
