I have a bunch of subtitled mp4s I'm trying to make playable on my PS3, (with the subtitles.) I've found the best solution for subbed media is to just put it through multiAVCHD. However it didn't mux the soft subtitles from the mp4s. According to Mediainfo the subs are "timed text". I tried extracting the subs with mp4UI but it was unable to read them properly. MP4Box successfully demuxed them as .ass. What's going on here?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
do u teevee?
Multiavchd supports ass/ssa subs. Tried add the ass together with the mp4?
Or does the ass not contain any subs? Check with a text editor. -
But have you tried add the demuxed ass file and mp4 in multiavchd ?
Ok this is really weird, I was wrong about the .ass. mp4box demuxed the subs track as a .ac3 file. I opened it in a text editor and the subs were there. I'm going to attach the aforementioned .ac3 file. What is the deal here? Here's the mediainfo log too:
General
Complete name : E:\anime\NinjaRobots\01 - An Open Door.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 222 MiB
Duration : 24mn 28s
Overall bit rate : 1 268 Kbps
Encoded date : UTC 2007-06-28 20:31:15
Tagged date : UTC 2007-06-28 20:31:15
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Format settings, GOP : M=1, N=5
Codec ID : avc1
Duration : 24mn 28s
Bit rate mode : Variable
Bit rate : 1 000 Kbps
Maximum bit rate : 3 032 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.121
Stream size : 176 MiB (79%)
Writing library : x264 core 54 svn-635M
Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1000 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Encoded date : UTC 2007-06-28 20:18:23
Tagged date : UTC 2007-06-28 20:31:23
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 24mn 28s
Bit rate : 264.6 Kbps
Maximum bit rate : 312 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 45.5 MiB (21%)
Encoded date : UTC 2007-06-28 20:31:20
Text
Format : Timed text
Codec ID : tx3g
Duration : 24mn 22s
Bit rate : 48 bps
Stream size : 8.49 KiB (0%)
Encoded date : UTC 2007-06-28 20:22:24
Tagged date : UTC 2007-06-28 20:31:23do u teevee?
Has anyone else here been 'zapped' by "text-enhance"
By DB83 in forum ComputerReplies: 45Last Post: 27th Oct 2011, 05:50 -
Need help: Trouble importing/capturing a "locked IFO" on DVD
By mattday79 in forum Video ConversionReplies: 3Last Post: 1st Jan 2011, 17:29 -
By mattday79 in forum CapturingReplies: 3Last Post: 1st Jan 2011, 13:41 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
i have trouble with "Cyberlink PowerDirector6" capture from Turtl
By Chief ADFP in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2008, 19:09
