ok so i got ffmpeg to hardcode subs by using an avisynth script
However only by using xvid. The problem is i need DivX 6.0
i already installed the codec but dunno what its called in the
codec list of ffmpeg -> GUI AutoFF.. Is it the mpeg4?
Avisynth Script:
Anyways tried libxvid which works perfectly, however my
standalone player sucks at playing xvid. But loved to play
Divx. I even bought the Pro of DivX for this project.
So i tried with mpeg4 but ffmpeg gives me this error:
Any help would be greatly apreciated[mpeg4 @ 064D7110]timebase not supported by mpeg 4 standard
Error while opening codec for output stream #0.0 - maybe incorrect parameters su
ch as bit_rate, rate, width or height
i had bitrate set at 1400kbit
rate at standard 23.98
and width 720
height 384
when playing xvid i get alot of color bleeding, traces of fast moving objects etc.
"timebase not supported by mpeg 4 standard" means that you should set the framerate manually I guess. Like -r 25 for 25fps. Use same framerate as your source.
Or use something else to convert like virtualdub, load the avs script, under video->compression choose divx and under audio->compression choose mp3. Save as a new avi.
Convert MKV with .ass subs to mp4 with ffmpeg
By bearnado in forum Video ConversionReplies: 2Last Post: 1st Mar 2012, 02:21 -
Add hardcoded subs in a mkv file
By joost1 in forum SubtitleReplies: 9Last Post: 2nd Nov 2010, 16:54 -
Mkv to mp4 with hardcoded subs on Mac
By Mauserman in forum MacReplies: 3Last Post: 30th Aug 2009, 03:19 -
Directly ripping hardcoded subs on DivX/AVI from DVD
By drstupid in forum SubtitleReplies: 2Last Post: 4th Jan 2008, 15:51 -
What Tool: Type in subs while viewing subs from hardcoded video
By kpic in forum SubtitleReplies: 3Last Post: 6th Jun 2007, 19:29
