Hello, i have a 7.4 GB 720p .mkv video file and i want to burn it on a DVD9 (8.5 GB) and play it on a stand alone avchd bluray player ( sony ). i dont know which tool will give me better results, AVS2DVD or multiAVCHD. the idea is to keep the aspect ratio and the quality at it's best.
Thanks in advance!
Peace.
If you have an AVCHD capable player, use Multi-AVCHD and output an AVCHD structure, ready for burning to disc using Imburn. If you want a standard DVD for playing on any DVD player, you can use Multi-AVCHD, or AVStoDVD. Both use the same encoding engine (HCEnc), but AVStoDVD gives you more menu options.
AVCHD preserves the full 1080 or 720p resolution, DVD requires downscaling to SD resolutions, so you take a noticeable quality hit.
There is a good chance that your MKV file does not have a compliant resolution and will have to be re-encoded, which on your system (assuming your system pecs are correct in your profile) could take 5 - 6 hours or more.Read my blog here.
Simplest way to convert 1080p h264 mkv to 720p mkv?
By aer in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2011, 10:16 -
Best quality option to convert 1080p mkv to 720p mkv
By carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 07:17 -
25fps 1080i mkv convert to 24fps 1080p or 720p mkv?
By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 09:57 -
2 x 720p AVI with DTS - need 1 x 720p MKV with AC3
By snadge in forum Video ConversionReplies: 2Last Post: 25th Oct 2009, 12:38 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 19:23
