While searching for a cheap video capture card the Hauppauge USB-LIVE2 kept coming up. According to the specs it looks pretty good for non high def stuff and I was wondering if anyone has any experience on this thing.
I can't help but get grumpier as I get older...
You want a "cheap video capture card" but expect it to be "pretty good" -- really?
Isn't that like asking for a high-class whore?
It's an oxymoron.
You can have cheap, or you can have good -- rarely are they the same thing.
What's your realistic budget for a card?
And then what do you want to do?
With that information, you can get some good suggestions.Want my help? Ask here! (not via PM!)
The "What is your computer spec including software you want to use?","What do you want to do?" and "What is your time worth?" are key sort questions.
You need a process design before you start buying stuff.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If analog standard definition is all you want you can buy used on auction sites.
If you want simply to make a dvd from a captured source I'd recommend looking for a hauppauge 250 or 350 capture card. They are internal pci cards (original pci not the newer pci-e). They do hardware mpeg encoding and do it very well - for dvd mpeg2 or even vcd capping if you want.
I don't believe its possible to capture in an avi container for either divx or dv-avi at all with those but that may have changed with a later upgrade since the last time I used one several years ago.
If you want dv-avi or divx capturing on a hardware card you'd have to look at some other card that I can't offer recommendations on.
But staying standard definition on input capturing will keep your costs down. And if you don't mind buying used and a generation or two older you'll save even more.
High def capturing like component or hdmi will be a different story altogether.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Need a recommendation on a new capture card/device
By MJDore in forum Capturing and VCRReplies: 1Last Post: 14th Oct 2011, 15:56 -
Audio card recommendation please
By Zetti in forum AudioReplies: 1Last Post: 30th Jun 2011, 14:19 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2010, 05:50 -
Need Graphics Card Recommendation
By mysts in forum ComputerReplies: 4Last Post: 15th Mar 2008, 18:52 -
laptp capture card recommendation
By theduffer in forum Capturing and VCRReplies: 0Last Post: 2nd Mar 2008, 09:26
