Hi again,
As you might know from my previous posts, I've been having trouble when I play back a 5.1 AC-3 that I encoded with a couple different programs that I've tried. However, one app that does work for me is Audition and its Surround encoder. The problem is that its only output that works for me is a single 6-channel encoded Wave. This is not ideal. Is it possible to convert this Wave to an AC-3? I tried using BeSweet but it doesn't work. The log file reports that it didn't understand the input format.
The file that Audition outputs can be used by VirtualDubMod, and it does play each channel properly, but I want to use an AC-3 for use with DVD-lab Pro or DVD Flick. I tried using my Wave in both of those apps and the result was only Stereo.
Can someone please help me?
Thanks,
Justin
you can use avisynth with wavsource and soundout plugin
e.g.
wavsource("waveformatex.wav")
soundout()
you might be able to use eac3to, but I can't recall if it likes waveformatex, or the other version of wave
you might be able to use foobar2000
I would the 1st suggestion with avisynth -
Hi,
Eac3to can encode 5.1 wav files into .ac3, I think it should work ok with its built in Libav/ffmeg decoders.
If not you may have to fully install it with all the correct codecs taken from various other pieces of software,
Some of which are freeware and some are commercial.
I've just tested it by converting a 5.1 dts track into a 5.1 wav, and then back into a 5.1 ac3.
It worked OK and Eac3to only seemed to be using the built in codecs for the conversion from .wav to .ac3.
check out this link for a full list.
http://en.wikibooks.org/wiki/Eac3to/How_to_Use
After quite a bit of searching i managed to find 99% of the required stuff on the net for free..
also of interest.. and worth a read..
http://forum.doom9.org/showthread.php?t=148324
http://forum.doom9.org/showthread.php?p=1255699#post1255699
P.s I have used eac3to produced .ac3 files, with DVDLAB pro with no problems.
Cheers..Last edited by anaboland; 30th May 2010 at 20:22. Reason: clarification
Now I'm REALLY getting very peeved and very frustrated.
Please refer to my last thread:
https://forum.videohelp.com/threads/321338-Why-are-my-Surrounds-playing-on-the-front
I state in that thread that my DVD software plays all channels fine, but I tried a different DVD and it seems that they don't ALL work properly. I just tried The Terminator and it's only my FL+FR.
UGH! That link was working, but now it's not. If you look at the main Audio forum, you'll see the thread I'm referring to.Last edited by takearushfan; 30th May 2010 at 22:23. Reason: Hoping someone has patience with me!
Update - I forgot to mention that I'm using AC3Filter. I took a shot in the dark and reset its registry settings, then reconfigured AC3Filter's settings... to specifically state "5.1". NOW my DVDs are playing properly, out of all 6 channels. HOWEVER, Audition remains the only app that encodes a Wave that'll play through all 6 channels. Soft Encode, SurCode, "Wave to AC3 Encoder" and eac3to all result in the Surrounds not working. I hate not understanding what I did to change things. I used to use Soft Encode all the time and it always worked. What could I have possibly done to stop the Surrounds from encoding?
AviSynth's WavSource won't load WAVE PCM files
By random in forum AudioReplies: 7Last Post: 7th Aug 2016, 13:31 -
Which player S/W and H/W can play 12.3 Mbps 48 KHz 8 channels PCM wave?
By Bonie81 in forum AudioReplies: 3Last Post: 8th Jul 2011, 20:30 -
On the Wave-Format-Extensible thing
By El Heggunte in forum TestReplies: 0Last Post: 28th Apr 2011, 21:03 -
Why did my DTS track get converted to 2 ch. PCM ?????? Please HELP :(
By Spdngblt56 in forum AudioReplies: 2Last Post: 12th May 2010, 03:17
