Hi
I´m trying to convert a movie from DivX->VCD
But I got a lage problem with the sound. its 5ch (Dolby digital)
I tryed to convert the sound in V.D but the program refuses.
Any ideas?
Regards
Sarley
I had a problem like this recently, where the sound could not be processed by VD off a DIVX. I had to decompress the audio file using the decompress utility in AVI2VCD (gives you an AVI that contains uncompressed audio), then process the resulting file in VD (was resizing/adding subtitles), then frame serve to TMPGEnc for VCD encoding.
And even then, there was a delay in my audio, so I had to manually adjust that delay in VD.
Bit complicated if you ask me, especially considering the subtitles were initially in SAMI format and it took me forever to find a way to convert them properly to SSA format. -
dnld ac3dec and drop your ac3 file onto the icon and it will give you a wav, then you can load it into tmpg[/u]
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 11:43 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 21:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
