ok, i have my 360 plugged into my computer monitor via VGA cable.
Now i have to keep switching cables into monitor from 360 and computer. i am planning on buying a VGA box to be able
to switch sources through the box. my Q is when i do that if i download a capture service on my computer will i be able to record the 360 footage when its on or do i have to buy a capture card. if i have to get a capture card could someone suggest a extremely cheap method or a really cheap capture card...like 50$??
Your help is deeply appreciated.
Filling out your profile completely (where in the world are you?), mentioning your gaming habits(Do you purchase games from overseas?) and you reading-up on PAL and NTSC video formats should be your first step.
Yes you'll need a capture card to record the video.Originally Posted by sxemosher
If that truly is your budget you will not be able to record in high definition. You'll need to look into a card that does standard definition. If you simply want to make a dvd from your recording I'd recommend looking for a used hauppauge 250 or 350 capture card. They record into mpeg2 that will be ready to import into any dvd creation software.
If you want to record into avi for something like divx you'll need to look into a different capture card.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Help encoding 360 x 360 videos (spherical movies)
By sapojow in forum Video Streaming DownloadingReplies: 29Last Post: 1st Aug 2009, 20:23 -
Total noob needs help encoding from Xbox 360 footage
By FreeBaGeL in forum Newbie / General discussionsReplies: 0Last Post: 17th Feb 2008, 15:27 -
Captureing Video off tv
By MoDifiy in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2008, 01:23 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 10:06 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
