I have an ATI AIW 8500dv now, and the driver support is making this card the worst investment I think I've ever made!
a.) the video in looks horrible from my set-top digital cable box.
b.) the video out to my tv is really awful! (4"borders top and bottom of dvd playback, avi playback really sux, e.g. everything going to the tv is hazy, distorted, etc).
c.) the built in tuner is a joke
My main use of this pv is capturing movies from cable and output to my television.
There has to be a better solution than this!
Or is this as good as it gets?
well as to the hazyness, are your input or output cables close to a power supply or some such device that could cause electromagnetic distortions? as to the 4" borders do you mean the borders they have on all dvds?
I have the Radeon AIW, and yes, the quality sucks.
My CPU is an Athlon 1.2Ghz w/256megs and a seperate, 60Gig HD.
I could have bought a TIVO for less than what I put into this, and the quality would have been so much better. On my brothers TIVO you can't tell the difference between live and recorded. With the Radeon, I appear to get only half the resolution of a normal picture. Makes video originated programming (like the loal news) look almost film like.
Thats not what I wanted. -
The signal cables are all clear of any AC/DC cables etc...
as far as the borders are concerned, yes I get the normal borders from dvd playback but far worse ( I tested with my standalone dvd player)
adjusting the aspect ratio in the MMC dvd setup box did'nt help at all.
Is there a better card out there for my needs?
thx
klumbz
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
why does my ATI VIVO quality suck so bad
By bacobits in forum Capturing and VCRReplies: 3Last Post: 2nd Jan 2008, 21:22 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 03:28
