Using Adobe Flash Media Live Encoder, I'm recording a copy of the stream during Live streaming events (as an flv). I would like to "mark" certain points in the recording with Flash cue points to serve as navigation points at playback time. For example, speaker intro, his first point, his second point, etc.
Can I dynamically inject those points, on the fly, so to speak, during recording? If not, what is the best way to quickly and easily inject those navigation cue points after recording, without having to re-encode the video file?
Best wishes,
Eye for Video
Not possible after it's encoded because the cue points have to be on I-frames (keyframes).
So your navigation points might be off quite a bit, depending on how you setup your keyframe interval
I don't use FMLE , so I don' t know if you can dynamically do it either -
I can adjust the keyframe frequency on a per second basis, which in a 1 hour video is plenty accurate enough for my purposes.
So if the keyframes are there, do you have any recommendations for adding cuepoints after the initall recording?
Or is it possible to use either an xml file or some other method to navigate to a place in the timecode or navigate to 1:30, for example?
EfV -
yes you can , you could use flvtool2 for example -k (onCuePoint)
the exact method and code is going to depend on what front end you are using, and what protocol for streaming
for example, in flowplayer
http://flowplayer.org/demos/events/embedded-cuepoints.html
just search google for "cue points" + whatever front end you are using, there should be lots of posts
some front ends have customized drop down menus for your navigation points, and you can use .xml files
one potential problem with setting 1sec keyframes, is that it can impair compression efficiency (would need larger bitrate for similar quality)Last edited by poisondeathray; 30th May 2010 at 10:52.
Converting DVD to Flash with cue points?
By NoFunction in forum Video ConversionReplies: 2Last Post: 26th Sep 2010, 12:14 -
Software For Recording Flash Video
By subsync in forum Newbie / General discussionsReplies: 6Last Post: 20th Jul 2009, 05:20 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
Recording audio from Flash website
By Ryosuke_Gunma in forum AudioReplies: 3Last Post: 27th Jul 2007, 13:14
