I'm using a Sony VX2100 to Live stream events. I really don't need to tape the event, but if I don't, the cam will go to sleep after a few minutes. If I do use a tape and record the event, I have to shut down the encoder (Adobe Flash Media Live Encoder) while I switch out the tape.
Running the cam with no tape in it works but it is throwing in some of the build in scene transitions every so often. So the input looks just fine.. but randomly the output will show these scene transitions (part of built in editing capabilites of the cam).
So what's the best way to stream Live events without recording to tape with the VX2100?
Best wishes,
Eye for Video
we used to have some canon gl1's that had a problem like that. the trick we used was to put a tape in the transport but left the cover open. don't know if it will work on a vx2100 though....
What kind of bed do you sleep on?
By johns0 in forum PollsReplies: 21Last Post: 9th Jan 2010, 07:58 -
How much sleep do you need each day?
By Baldrick in forum PollsReplies: 26Last Post: 15th Dec 2009, 01:46 -
Wireless problems with long hibernation/sleep.
By Dr.Gee in forum ComputerReplies: 3Last Post: 20th Nov 2009, 18:49 -
sleep does nothing to a philips 5140
By BirdDaddie in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Jun 2007, 17:52 -
Eyecup for vx2100 ?
By j0nathan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th May 2007, 16:41
