HI,
Looking at buying a new capture card. I used to use an asus3800 TNT2 card that had the capture built in, but recently bought a geforce2 card and need a cap card to run alongside it
My PC Specs are
AMD XP 1700+
256M Ram
40G HDD
Win ME
Now the choices I have in my price range are low - end cards.. I'm stuck between these:
-generic 878 chipset cards (TV excel, MTV878)
-Flyvideo 3000
Whats gonna be my best bet? Anyone relate any experiences with these cards?
At the moment I'm leaning towards the flyvideo.. however what I really wanna know is if I can use virtualdub with it, or just its bundled software (it uses a philips chipset I know nothing about).. anyone had any experince doing caps with it? Or would I be better off just sticking with the generic 878 cards?
I am considering upgrading to XP in the next 3 months, so thats a consideration too
Any thoughts/suggestions?
Thanks - great (and VERY informative) site :P
Do not get the FlyVideo! as a technician i've had the displeasure of working with that card, and getting intouch with clients who bought the card, and i've yet to see one that is happy with it.
Get a bt878 based card, i'd recommand something along the lines of PCTV PCI or Hauppauge WinTV-Theater (or WinTV-Dbx for simpler card, not the WinTV-Go, it's crap!).Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Glad to be of help!, let me know if you require any further assistance!
Best Regards,
Sefy Levy,
Specific Panasonic VCR buying advice needed
By Sainsbo_McManus in forum RestorationReplies: 8Last Post: 28th Nov 2011, 19:30 -
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 16:15 -
Advice needed for buying new hard drive.
By dafoe in forum ComputerReplies: 4Last Post: 6th Feb 2009, 16:54 -
Multiple DV source Capture card/box help/advice needed please
By OdubruS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Dec 2007, 11:08 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
