Hi, this may sound stupid, but I was just wondering if there is a way to limit the capacity of a 32GB SDHC card to 25GB.? This is just a precautionary measure I would like to take, to ensure easy backing up AVCHD movies directly to Blu-Ray Disc. I currently use 4GB and 8GB and burn to DVD-R or DVD+DL. I'm planning to move to Blu-Ray but wanted to make sure this is possible before I invest on the card and the burner. I use Windows XP Pro and in the format window there is a drop down box that says "Capacity" but there are no other options except for the maximum amount, and no place to specify a custom amount. Any ideas?
not that i've ever run across. but you could put a 7GB file on the card to limit the free space.
That seems to be the easiest and best way to do it. If you're going to limit the capacity, you may as well be in full control of it.
Even if you don't have a single 7 Gig file, you could always create a folder and put several files in it until it meets your 7 Gig padding. -
Thanks.. I never thought of doing that. I guess that should work just fine for want to do.
How to recover large AVI file after formatting digital camera memory card?
By 2Bdecided in forum RestorationReplies: 2Last Post: 5th Aug 2011, 13:01 -
Can I use a micro SDHC card in a DSLR Camera?
By jbitakis in forum Capturing and VCRReplies: 2Last Post: 5th Apr 2011, 04:13 -
High Res Time Lapse images to AVCHD video (play on Viera TV via SDHC)
By Deefa in forum Video ConversionReplies: 5Last Post: 16th Jun 2010, 05:21 -
Storing avchd video on flashcard (SDHC)
By haschopapa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 13th Dec 2009, 10:52 -
DV Tape vs. SDHC for a HD camera
By Cazz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 49Last Post: 3rd Jun 2009, 16:33
