  1. Hello everybody!
    I have searched the forum but I haven’t found the answer to my problem.
    I have a serious problem with subtitles which I cannot solve.
    From time to time when I play a 1080p or 720p mkv movie on BS player Pro 2.52 b1030 I experience some difficulties.
    When I play such a mkv movie with external subtitles – they lose synchronization. However, there are mkv files with external subtitles which run without problems on BS player .
    I don’t know what is wrong. The same movie played on MPC HC and with the SAME subtitles goes without any problems.
    Do I need any filter to make it work?
    I really like BS player and I wouldn’t like to give it up for MPC HC.
    Is there any remedy for my problem?
    I will greatly appreciate any comment.
    Best Regards
    Feb 2004
    Australia
    Run gspot or media info to discover what differences exist between working and non-work mkv's in bsplayer.
    Once discovered you should then search for a solution to remedy the fault.
    MPC HC ... I'm fairly certain it use it's own inbuilt decoders.
