  1. Hi
    I'll really appreciate some info about good standalone players for Dvd, Divx, Xivd, Blu-ray, Mkv..... on the market .
    I'm looking for something not too expensive but I can spend some money if the player will be good.
    Thx for any suggestions and information.
    JKoniak
  2. whats your budget? if you are looking for a player between 2 and 3 hundred .check the Panasonic DMP-BD85K $209
    http://www.amazon.com/Panasonic-DMP-BD85K-Enabled-Blu-Ray-Player/dp/B0038KR8WM/ref=dp_...5661570&sr=8-6
    • Wireless LAN system: Wi-Fi enabled with included adapter
    • 3:2/2:2 Pull-down progressive processing: Yes
    • Up-conversion to 1080p playback: Yes
    • Video D/A converter: 148.5MHz/12bit
    • Digital noise reduction: 3D-NR/ Integrated NR
    • Deep Color: Yes
    • x.v.Color: Yes
    • Picture mode: Yes (Normal/Soft/Fine/Cinema/User)
    • Picture adjustment: Contrast, Brightness, Sharpness, Color, Gamma Correction
    • Dolby Digital Plus/ Dolby TrueHD: Decode and Bitstream output
    • Audio D/A converter: 192kHz/24bit
    • Dialog enhancer: Yes
    Disc/Media Compatibility
    • BD-ROM: BD-Live, BONUSVIEW
    • BD-RE / BD-RE DL: Version3; JPEG
    • BD-R/ BD-R DL: Version2; DivX/DivX HD
    • DVD-ROM: DVD Video disc
    • DVD-RAM: DVD-VR; JPEG; AVCHD
    The LG-BD590 is a nice player .it comes with a 250gb hard drive
    http://www.amazon.com/LG-BD590-Network-Blu-Ray-Player/dp/B0036WT1V8/ref=sr_1_1?ie=UTF8...5661311&sr=1-1
  3. http://www.iboum.com/net-media-players.php
    For standalone HD players, prices beginning at $80.
  4. Banned
    Freedonia
    jarko - Please note that media players, such as in creamyhorror's link, are much more tolerant than BluRay or DVD players about what they will play in terms of Xvid/Divx, MKV, etc. If you go with a BluRay player, you may find that you have to convert or re-encode certain files. We had a thread just a few days ago about some DVD or BluRay player that required a (in my opinion) not very obvious setting to be used during H.264 encodes or it would refuse to play the file.
  5. Thanks, Guys
    I'm looking more for standalone player for Divx, Xivd, Mkv, etc. than for Blu-ray player.
    JKoniak
