Results 1 to 9 of 9
  1. How to calculate OAR (Original Aspect Ratio) ?
    Hi,
    I have 2 Versions of the same Movie.
    The AR of the DVD ist 1.30 and the AR of the HDTV Airing is 1.78.
    The 1.30 frame is cropped left/right |Resolution after cropping black bars 625:480
    The 1.78 frame is cropped top/botton |Resolution after cropping black bars 1912x1074
    (it's possible that the 1.78 is also cropped left/right. No idea)
    How can i find out the Original Aspect Ratio of a Movie?
    Thanks a lot!!
    Here is a picture of both frames (i know it's not 100% the same frame...but close ^^)
    Oct 2005
    666th portal
    no way to tell for sure without the name of the movie, but it's possible the were both pan&scanned from a 2.35/1 source.
  3. With some movies both the widescreen theatrical and TV (4:3) versions are pan-and-scans of the full film frame. Rabbit-Proof Fence is one example. Finding Nemo was rendered in both 16:9 and 4:3.
  4. Thx for your help guys !
    The title of the Movie is "Subspecies".
    It's a cheap Horrorflick filmed in Romania (1991)
    I checked imdb for oar...nothin there.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Go to the imdb database for original aspect ratio. They also often list the VHS/Laserdisc/DVD release aspect ratios. Wiki is also good.
    For example
    http://www.imdb.com/title/tt0031381/technical
    http://www.kiva.org/about
  6. Member edDV's Avatar
    Mar 2004
    Lots of info here. Still looking for aspect ratio.
    http://en.wikipedia.org/wiki/Subspecies_%28film_series%29
    http://www.imdb.com/title/tt0103002/
    One option is to research the director and studio and see what they used for other films in the same year.
  7. @edDV
    Thanks Mate.
    Somehow it's really difficult the find the OAR of that Movie.
    before posting here i already checked:
    imdb, wiki, dvdcompare, dvdbeaver, lddb
    help ??????????????
  8. deleted post reply: nevermind already covered
  9. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    According to Amazon it's 1.85:1 see http://www.widescreenmuseum.com/widescreen/evolution.htm
