I have a bunch of x264 encoded files (.avi) that have the wrong aspect ratio : they're 16:10 when they're supposed to be 15:9.
I want to change the aspect ratio but I don't want to re-encode them as I'll lose quality and it would take days.
So far, I've used on other x264 videos a little program called H264 Aspect Ratio Modifier(modified them form 16:9 to 16:10), but it can only modify predefined AR's to other predefined AR's and custom ones to other custom ones, so it doesn't let me do anything, as 16:10 is predefined but what I want (15:9) is not.
Do you guys have any idea how I can do this without re-encoding? It would be a very big help if I were able to do this...
With MPEG4Modifier can you set a custom aspect ratio.
you can set it in the container level as well e.g. mkvtoolnix
or change SAR in the bitstream with an experimental ffmpeg version
http://forum.doom9.org/showthread.php?t=152419
(note SAR in AVC terminology is the same as PAR in conventional terminology, so you have to figure out the correct ratio) -
Baldrick, it seems that MPEG4Modifier doesn't support H264, so I couldn't do anything with it.
poisondeathray, I'm going to have a look at that link, but it seems kind of complicated, I might need help (have a few questions...). -
Hahaha, awesome little tool... (I mean the ffmpeg one)
I knew about its existence but was wary of trying it due to being command line based. Just awesome.
Yeah, I had to figure out the correct ratio (25:24 in my case) and it worked perfectly.
Thanks (again
) for your help poisondeathray.
Can I change the pixel aspect ratio in an x264 AVI without reencoding?
By Calidore in forum Video ConversionReplies: 24Last Post: 16th May 2018, 17:24 -
avidemux - x264/mkv with chapters? + aspect ratio question.
By simon_h in forum DVD RippingReplies: 2Last Post: 22nd Nov 2011, 14:13 -
MeGUI x264 Aspect Ratio Tag?
By reakt in forum Video ConversionReplies: 11Last Post: 6th Aug 2010, 18:44 -
DVD to x264 mkv gets wrong aspect ratio
By kramboa in forum DVD RippingReplies: 8Last Post: 3rd Nov 2009, 10:28 -
aspect ratio problems using fairuse wizard with x264
By scarlac in forum DVD RippingReplies: 10Last Post: 13th Jul 2009, 10:01
