Hello. It may seem a bit strange, but this is what I need to do (under Windows Xp): extract the frames from a video to a single jpg.
Very important, the extraction would need to be synchronized with the video. And if possible, at the end of the video, the extraction would restart from the beginning. Is this possible?
Besides this, I haven't been able yet to extract frames from any video using the command line, always getting the error about I/O and truncated/damaged files. Using Super though the extraction works well.
Thank you for your help.
Hello Baldrick, thanks for answering. I know it seems strange. The idea is to have another program (a music visualizer), that can read jpgs but not video, read this single jpg 10-20 times per second. Very important is that the extraction should be as synched as possible with the video, since normal extraction is much faster. I'm using ffmpeg under Windows Xp.
Besides this, when I use
I get the message of I/O error and only frame 1 is extracted.
extraction of teletext from video streams
By ty7op5 in forum SubtitleReplies: 0Last Post: 9th Aug 2011, 15:29 -
subtitles 25fps, video 24fps both synchronized - converting to DVD, a mess
By Ze Tomes in forum SubtitleReplies: 10Last Post: 27th May 2011, 00:45 -
Ac3 Shorter Than Video after extraction.
By Womb4T in forum AudioReplies: 9Last Post: 18th Dec 2010, 18:28 -
playing mkv - Audio is not synchronized with video
By Shasoosh in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jul 2007, 11:26 -
video extraction
By siopawman in forum EditingReplies: 2Last Post: 9th Jun 2007, 18:42
