Hi,
I am using a Konka-9102 portable TV stick to record DVB-T in my country (specifically with Presto PVR! version 5). It records to a .MPG file. According to MediaInfo these are the file details:
Container and general information:
MPEG-TS" 326 MiB, 16mn 31s
1 video stream: AVC
1 audio stream: AAC
First video stream
720*576 (4:3), at 25.000 fps, AVC (Component) (Main@L3.0) (CABAC / 4 Ref Frames)
First audio stream
AAC
When trying to play it in any media player (windows, mpchc, vlc), the video is fine but there is no audio.
My goal is to edit the commercials out eventually and convert it to avi or mkv. I found that i can edit the file with TSSniper and h264ts_cutter but these applications does not recognize the sound either.
I need your help and suggestions please since i am breaking my head over this issue, how can i extract/play the audio on these files?
Many thanks in advance.
Results 1 to 11 of 11
Last edited by Omega81; 28th May 2010 at 17:50. Reason: Accidentally pressed enter at the topic field :P
what kind of aac audio specifically? use mediainfo in text mode (view=>text)
latm/loas aac are not decoder properly, and require a workaround
do you have ffdshow installed, and aac enabled in the configuration?
is the extension .mpeg or .ts or .m2ts ? mediainfo says it's mpeg-ts, which suggests a transport stream. What happens if you rename extension to .ts or .m2ts? What happens if you re-wrap with tsmuxer?
please post the mediainfo text mode informationLast edited by poisondeathray; 28th May 2010 at 17:11.
As i said TSSniper can't read the audio stream. I have VideoRedo TVSuite 3.20.1.587 installed and it does not support the file type (it says H264/AVC video streams are not yet supported). Also there is no version 4 to my knowledge. TSPE failed to open the file.
This is the audio part from text mode, nothing specific about the codec:Originally Posted by poisondeathray
Audio
Menu ID : 2 (0x2)
Format : AAC
Duration : 16mn 30s
Video delay : -548ms
I have ffdshow installed as part of the Combined Community Codec Pack. Inside the configuration, under Codecs enabled AAC is enabled as libfaad2. -
I edited my post above, can you re-read it and answer the questions regarding the extension (ie. .mpg vs. .ts)
The extension is mpg, nothing changes if i rename it to ts. I will see what tsmuxer can do with it.
MediaInfo text mode:
Code:General ID : 2 Complete name : C:\Users\OMEGA\Desktop\Ch2-201005211936_0001.ts Format : MPEG-TS File size : 326 MiB Duration : 16mn 31s Overall bit rate : 2 754 Kbps Video ID : 2593 (0xA21) Menu ID : 2 (0x2) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=1, N=60 Duration : 16mn 31s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Color primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM Transfer characteristics : BT.470-6 System B, BT.470-6 System G Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601 Audio ID : 2594 (0xA22) Menu ID : 2 (0x2) Format : AAC Format/Info : Advanced Audio Codec Duration : 16mn 30s Video delay : -548ms Text #1 ID : 2608 (0xA30) Menu ID : 2 (0x2) Format : DVB Subtitles Language : Hebrew Text #2 ID : 2609 (0xA31) Menu ID : 2 (0x2) Format : DVB Subtitles Language : Russian Text #3 ID : 2610 (0xA32) Menu ID : 2 (0x2) Format : DVB Subtitles Language : Arabic Menu ID : 2592 (0xA20) Menu ID : 2 (0x2) Duration : 16mn 31s List : 2593 (0xA21) (AVC) / 2594 (0xA22) (AAC) / 2608 (0xA30) (DVB Subtitles, Hebrew) / 2609 (0xA31) (DVB Subtitles, Russian) / 2610 (0xA32) (DVB Subtitles, Arabic) Language : / / Hebrew / Russian / Arabic
When you say nothing changes, do you mean no audio in mpc, or vlc ?
I think the problem is most mpeg-ps splitters (what is used if you have .mpeg), do not handle aac audio in mpeg program stream. MPEG-TS (transport stream) can handle aac, and is more common
You can also try re-wrapping with mkvtoolnix
And another option would be to demultiplex with DGAVCIndex into elementary streams, then rewrap with tsmuxer -
Thanks for the quick replies, i really appreciate it.
Yes, no change meant still no audio.
I tried tsmuxer, when i added the file as mpg it said some tracks not recognized. This tracks was ignored, no tracks were showing. I changed the file name to ts and tried that again: I got the same error message but then only the video track appeared under the tracks section. Started remuxing anyway and of course got only video.
I will try the other tools you mentioned. -
poisondeathray:
Mkvtoolnix says the transport stream file type is not supported either.
DGAVCIndex can read the file just fine, again without audio. However it does recognize an audio track as AAC LATM/LOAS which you mentioned requires a workaround, can you give me info about that workaround please? -
Yes, the nasty workaround is use winamp to decode that demuxed stream and encode to .wav, then import that into your editor
These streams have been broadcast in other countries for a couple years now (new zealand) , and there is still very few software that can properly handle them
EDIT : sorry, you're probably not familiar with dgavcindex or avisynth, you have to use file=>save project to demux the audio (or audio=>audio demux) . This tool is meant to frameserve video through avisynthLast edited by poisondeathray; 28th May 2010 at 18:04.
Why should get a delay when converting H.264/MPEG-4 AVC?
By Leo99 in forum Video ConversionReplies: 31Last Post: 16th Apr 2012, 14:40 -
Editing/converting MOV MPEG-4 AVC fies
By yurkyurk in forum Video ConversionReplies: 1Last Post: 23rd Jul 2011, 12:46 -
Converting from mts to MPEG 2 I-frame HD in an AVI container
By shaunthesheep in forum Video ConversionReplies: 68Last Post: 8th Jun 2011, 08:08 -
Editing H264 MPEG 4 AVC .ts files?
By grave101 in forum MacReplies: 14Last Post: 24th Nov 2010, 05:12 -
Converting H.264/MPEG-4 AVC to DVD
By KiteFlyer in forum Video ConversionReplies: 1Last Post: 23rd Jan 2009, 14:36
i have found something regarding this workaround and will test it later.
