Results 1 to 10 of 10
  1. Many songs on YouTube that I like that aren't on Itunes. Iv already tried by using total video converter, but it is not supporting for the mobile KC750 model. It was supporting for some mp4 files but not for all. What are normal properties of mp4 files to play in mobile, codec to convert???
    Apr 2004
    Miskatonic U
    Every phone is different. If it will play standard iTunes material then use Xvid4PSP and choose the standard MP4 output. Better yet, use Firefox and Video Download Helper, and where possible, grab the MP4 version directly from youtube.
    Read my blog here.
  3. Originally Posted by guns1inger View Post
    Really quick reply
    But I do t know the difference the standard MP4 (u said) and the MP4 in mobile.
    Apr 2004
    Miskatonic U
    You mentioned iTunes. Does your phone play videos from iTunes ? If so, it will play base level MP4 and the standard MP4s from youtube.
    If you have a video that does play, use mediainfo to find out how it has been encoded, then encode to match those settings.
    Read my blog here.
  5. Always the video I downloaded form youtube has black bar in the top and bottom, sometimes it really bothered me.
  6. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Why do we need to know this? It just sounds like you're trying to get music for free. I bet that I could find the song on one of the music providers in about 10 seconds.
    Try checking your manual or the phone's support site. They probably know more about it than anyone here. Try 3GP. Also, try reading some tutorials and do a little research.
  7. Try checking your manual or the phone's support site. They probably know more about it than anyone here. Try 3GP. Also, try reading some tutorials and do a little research.
    What's the point of 3GP, I just want to crop the black bar. Any idea?
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If the video is wider than your phone screen then you will have to crop the bars, then crop off the sides, then resize, then re-encode. Otherwise it will either put the bars back, or stretch the video to distort it.
    But you still haven't said what type of video you need to output. What does your phone support, exactly ?
    Read my blog here.
  9. Originally Posted by guns1inger View Post
    Oops,so complicated operating steps. I do need a video converter that has the crop function. And if it can transfer the video to all kinds of format, better, so that I can use it in other purpose. And my firend have recommend me one, I am trying.
  10. Member usta's Avatar
    Jun 2009
    Netherlands
    Make it simple. Get Format Factory, open the video and select All To Mobile Device and in the list of presets select SonyEricsson K series. The converted video should play full screen by default.
