    Jan 2002
    Hi,
    I am trying to find a feeware program that will create full dvd covers.
    I need something that will let me create a professional looking front & back cover as well as a spine to insert in DVD cases.
    Any help would be graeatly appreciated.
  2. Just use Photoshop. Use layers to make it look really professional with fancy text. Create an image the size of the DVD cover, measure to find where the spin goes, and you're set.
  3. If You do a WEB search you will find that a number of sites have templates available for Corel Draw, Photoshop and even MS Word for just about all CD/DVD/VHS products. I would use the DVD Cover Templates to start the search. I have found the ones for Corel Draw because that is the one I use, I did not save the site so.........search.
    Bud
