Hi all,
I have been using this software for awhile now and it has been great! Now I upgraded my system and have a Blue Ray player (LG BD570). If I create a DVD with multiple episodes, I can only play the first episode. I cannot select another episode from the menu. Is there a fix for this?
Thanks for you help!
Does the dvd work fine on your old dvd player or with a software dvd player? You shouldn't have to do anything different for a blu-ray player.
The DVDs all work fine with my old DVD players. I see the menu items for the episodes on the DVD but cannot select one of them. All I can do is select play and it will play the first one only. I thought maybe it was a known issue with the titleset interpretation by the Blu Ray. Or, maybe there is a known workaround. Thanks for your reply!
How do I take a Blue-Ray tv show and only get two episodes on one disc with
By slayer_of_all in forum Blu-ray RippingReplies: 0Last Post: 2nd Mar 2012, 18:22 -
The Ultimate Blue Ray Player...
By Tap_Artist in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Sep 2010, 15:54 -
What features to look for in a Blue Ray player?
By V Bot in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Feb 2010, 17:18 -
What Blue Ray Player for a PC is reliable
By lacywest in forum DVD & Blu-ray WritersReplies: 11Last Post: 7th Jul 2009, 16:50 -
Which blue-ray player to get?
By PhoenixGuard in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Oct 2008, 18:12
