I have been a long time user of applications such as Gordian Knot, meGUI and avi.NET and in all of those mentioned applications I have never had a problem with getting a resolution of either 640:368 or 624:352 and the final encoded avi looking really polished.
I have been reading alot about StaxRip recently and how so many people say it's the best encoder front end but I am totally confused with trying to get either of those resolutions without it spitting out massive AR errors (lit in orange)
Why does StaxRip tell me those resolutions are really wrong when other programs allow me them without no hassle and the outputs from the other applications have always been fantastic.
Why does StaxRip offer you resolutions that I have never seen before for example 640:272 or 720:421 totally strange and I don't want to use them.
StaxRip is stressful![]()
It won't offer you 720x421. The earlier resolutions you mentioned are for 1.78:1/1.85:1 movies or thereabouts. An AVI of 640x272 is for a much wider movie, 2.35:1 or thereabouts. They are also very common. If I were you I'd pay attention to those orange AR errors. You'd get the same resolution if done correctly using GKnot.
What do you take for a headache?
By johns0 in forum PollsReplies: 24Last Post: 14th Mar 2012, 16:19 -
3 TB HD headache
By Farscape1 in forum ComputerReplies: 12Last Post: 16th Jun 2011, 01:09 -
Interlaced Video Giving Me Headache!
By HamishT in forum Video ConversionReplies: 7Last Post: 2nd Jul 2009, 02:15 -
Staxrip giving me audio files
By JBWhiteley1 in forum DVD RippingReplies: 0Last Post: 11th Jun 2008, 01:10 -
Converting DVD-audio is giving me a headache (weeej, mission accomplished)
By Bresso in forum AudioReplies: 15Last Post: 12th May 2007, 15:55
