I am totally confused as to how to make a dl movie play on the TV!
I hear about codec,divx, do this try this, cut avi to fit ,dvd2avi, dvdx all in one, NTSC,PAL, Bitrate need to know.....![]()
Is there one simple way to make a downloaded movie play on your TV?
Instructions start to finish. Everyone seems to have a different way of doing it and then someone posts a reply "do it this way". Its very confusing , I've never burned a move but I want to very bad.
The tool section suggest different software to use but I have no idea which ones to use!!!
Also whats the difference between avi-mpg-mov-asf-rom-mpeg formats?
Can any of these be burned and watched on a tv? If not which format then?
Please help
Cotton
hey man go to tools /downloads section ok and download dvd2svcd ok the only program u need is either cce encoder or the best and easy one is the newest version of tmpnge encoder ok preffablly have a crack version ( dvdsoft.net!!) and everything is in the bundle select the folders and press start a couple of hours later ull have 2-3 images to burn with fireburner or cdr win ok simple stuff!
see ya
How do you make a simple html file showing list of files in a folder?
By yoda313 in forum ComputerReplies: 2Last Post: 6th Mar 2010, 20:12 -
I need to make a simple slideshow DVD
By jeffzilla in forum Authoring (DVD)Replies: 5Last Post: 25th Sep 2008, 02:52 -
DVD software to make simple divx data disk
By gthorley in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 13:28 -
Simple tool to make video from photos and short clips?
By largactyl in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2008, 11:45 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37
